Home » Audio » Speaker » New array - some questions
New array - some questions [message #22330] Fri, 15 October 2004 07:21 Go to next message
Bob Fawcett is currently offline  Bob Fawcett
I plan to build an array with some PE buyouts. I will be useing teh 269-568 4" pioneer and the 269-782 3/8" onkyo.
I plan to on 20 4" and 30 3/8" per cab. The cabinets will be about 7' tall with about a 9" wide front baffle. Both lines will have some power tapering. The cabinet will probably be sealed.
What cabinet volume would be appropriate, or how can I calculate it?
I am looking at 3/3/6/8 arrangement for the 4" and 5/5/6/6/8 for the 3/8".
Is this proper tapering?
Would a ported cabinet work better?
Any other comments.
Thanks
Re: New array - some questions [message #22331 is a reply to message #22330] Fri, 15 October 2004 09:58 Go to previous messageGo to next message
I'm building the same thing your making the only difference is I'm using 24 of tweeters aside.
Follow the link and put in the parameters of the driver in the database maintenance and run the program.
>>I am looking at 3/3/6/8 arrangement for the 4" and 5/5/6/6/8 for the 3/8". Is this proper tapering?
Yes and you will need to do it, I have to do this on my tweeter array for sure, I discovered that when I was testing the array.
Somewhat depends on where your x-over point to the sub is, but your still not going to get much below 100Hz. And with the somewhat hi Qts of the drivers it'll require a larger cabinet.
HTH
Bill W.
Re: New array - some questions [message #22332 is a reply to message #22331] Fri, 15 October 2004 10:02 Go to previous messageGo to next message
Dang it Link didn't take in last reply. Any way the address for Win Isd program is www.linearteam.org
Re: New array - some questions [message #22333 is a reply to message #22332] Fri, 15 October 2004 13:52 Go to previous messageGo to next message
Hi Bill,
Be sure to include "http://" in the address when using the "Optional Link URL" field. Otherwise, the system doesn't display it.
Wayne
Re: New array - some questions [message #22334 is a reply to message #22331] Fri, 15 October 2004 14:10 Go to previous messageGo to next message
Is 30 overkill?
What tapering did you decide on?
I plan on 100 to 160 cross for the sub, depends on what the array does.
What crossover points are you using? Sub and mid - tweet.
Thanks
Re: New array - some questions [message #22335 is a reply to message #22334] Fri, 15 October 2004 15:13 Go to previous messageGo to next message
30's not over kill you may just have to attenuate the tweeters a little more, I have to attenuate the tweeters a little to match the array gain to meet the 4" drivers sensitvity, so my tweeters array impedance is going to 8.188 ohm where as the 4" pioneers will have an impedence of 6.23 ohms. This calculates out to 99.45db for the tweeters and 100.09db for the 4's. I want to x-over at 100Hz to the subs,which is the lowest point on my old x-over, by the way I'm bi-amped on my system, and then planing on crossing over at 4Khz from the 4" to the tweeters. I havn't ordered any x-over parts yet I'm going to experiment with the 4k x-over slopes.
Tweeters are going to be reconfigured for 5/4/4/5 - 8.18ohm.
Woof's right now planing on 3/4/4/4/5 - 6.233ohm.
Bill W.
Re: New array - some questions [message #22336 is a reply to message #22334] Fri, 15 October 2004 15:22 Go to previous messageGo to next message
Messed up on my reply below the tweeters are
7/5/5/7 arrangement.
Going to try the woofers like in post below
3/4/4/4/5 - going to try first but not sure if I'll have to reconfigue for them just depends on what the line sounds like.
Bill W.
Re: New array - some questions [message #22337 is a reply to message #22335] Fri, 15 October 2004 15:35 Go to previous messageGo to next message
Hi Bill,
Do you think you'll have these baby's ready for the next Great Plains Audio Club meeting?
Wayne
Re: New array - some questions [message #22339 is a reply to message #22337] Sat, 16 October 2004 09:28 Go to previous messageGo to next message
lcholke is currently offline  lcholke
Great Plains Audio Club meeting? !
Wane, where is the next one? I would like to attend.
(and see these line arrays also)
- Linc
Re: New array - some questions [message #22340 is a reply to message #22339] Sat, 16 October 2004 14:39 Go to previous messageGo to previous message
Hi Linc,
I'm not sure where it will be yet. But I expect we'll all probably iron something out for early to mid November, just before the holiday season.
Wayne
Previous Topic: Singular horns
Next Topic: Stephens Trusonic 80FR
Current Time: Mon Nov 02 07:38:46 CST 2026
