Home » Audio » Speaker » More thoughts on slot vs. hole for mounting array drivers
Re: More thoughts on slot vs. hole for mounting array drivers [message #22293 is a reply to message #22291] Mon, 13 September 2004 15:17 Go to previous message
taylor is currently offline  taylor
Ive been thinking of how to slot mount my square frame 4" drivers and have come up with the following. Im going to cut a half baffle which will have 16 semi-circles cut in one long pass with a bandsaw (snake shaped) The cut will be larger than half a 4" hole to allow for a router guide. I will then router out 4 pieces of ply, using the template I just made to create 2 complete baffles. Two pieces will be big enough for tweeter mounting. I will glue and screw cross braces every few drivers,to mechanically connect the two baffles. The frames of the drivers should also provide a good connection. This will allow frame to frame mounting.
The other option is to cut the holes with a hole saw. The holes will be linked so the bracing is still needed. Two baffles can be cut at once if you fasten them to a sacrifical board with nails. I also shoot brads into the inside of the holes so the cut-outs dont move and stay mounted to the scrap board. This way, you can bore the holes, and not have to remove the plugs.If set up on a drill press, this is a fairly fast process. I use compressed air to clean the holes while cutting to lessen the chances of binding.
Hopefully, I will start this project next week!
taylor
Previous Topic: AG trio or JBL K2 9800?
Next Topic: Single driver cornerhorn
Current Time: Fri Nov 06 02:32:02 CST 2026
