Home » Audio » Speaker » Line array question using Bandor 50mm driver?
Re: More line array questions using the Bandor 50mm driver? [message #22285 is a reply to message #22281] Mon, 06 September 2004 07:38 Go to previous message
You can run the bandors full range with no ill effect except that they won't have great dispersion characteristics above 10kHz, but depending on the listening zone that maight not be problematic for you.
If you do go with tweeters then the usual crossover point is no higher than where the woofer 30 degree off-axis response drops to -6dB.
The sensitivity differential question can be addressed both by the wiring scheme, using different impedances of the woofer and tweeter lines to better match sensitivity, and with the crossover. With an 8 ohm woofer line, for instance, you can wire the tweets to 4 ohms or 16 ohms to raise or lower the relative tweeter sensitivity by 3dB for better matching.
It's a good idea to have the tweeter and woofer line heights reasonably close to each other, so that they will have the same radiation characteristics at the crossover frequency.
Previous Topic: Truncated horns
Next Topic: BR + TL + FH
Current Time: Thu Nov 26 09:42:23 CST 2026
