Home » Audio » Speaker » Driver spacing... Pro stuff
Driver spacing... Pro stuff [message #22193] Thu, 05 August 2004 22:27 Go to previous message
DSM is currently offline  DSM
For those wanting to roll their own Pro line array. Its often seen where two LF drivers are mounted side by side horizontal. Beware this can cause severe lobing. This week I did several test runs in the middle of nowhere (a big field) to prevent any interference. I noted as much as 20db nulls in the horizontal plane with drivers spaced 12" CTC at as low as 500 hz. Most are using only one driver to the hf xover. The other is low passed at a point depending on spacing. It is an obvious problem easily checked.
Keep 'em tightly spaced. Listen for nulls...start over. The empirical method. Its all a learning experience.
Previous Topic: PI TAD
Next Topic: High Efficiency Speaker Get Together Aug 14 in Houston
Current Time: Mon Oct 19 20:31:44 CDT 2026
