Home » Audio » Speaker » compression horn tweeter
Re: It won't work. [message #22177 is a reply to message #22176] Wed, 28 July 2004 14:57 Go to previous messageGo to previous message
It's the hieght; with a pathway of only a few inches there wouldn't be any throat impedance to load the driver, which for all intents might as well be in a baffle.
The mids depend on what you want for a low end. You can roughly figure their response with a program like WinISD from their specs, and their usable high end from the manufacturers off-axis SPL charts, not going higher than the frequency where you're -6dB at 30 degrees off axis.
A crossover to the sub is a must; use a real crossover, not Bass Blockers (which are fancily packaged capacitors in any event). You don't need a crossover if you're using a 7.1 receiver that has one built in.
Car audio softdomes are OK provided they have no wide mounting flanges.
An array on the center is not a good idea, as it would be too high to fit close enough to the TV screen, though an MTM is viable.
Previous Topic: new DIY speaker
Next Topic: Taking a wild guess here about cross-over design
Current Time: Wed Nov 04 00:29:40 CST 2026
