Home » Audio » Speaker » Double for 3db?
Double for 3db? [message #22088] Tue, 02 March 2004 03:38 Go to next message
Gregg is currently offline  Gregg
Greetings all,
I have a box full of good small speakers and plan to make a nice array. My mate says it will have 3db more for each speaker added but I think it's 3db each time the number of speakers doubles. Which is it? What is better in a room, a line of speakers or a square bessel array? My mate says the line is better outside and the bessel is better inside the room. It that true? Cheers,
Gregg
Re: Double for 3db? [message #22089 is a reply to message #22088] Tue, 02 March 2004 08:44 Go to previous message
You won't get 3db everytime you add a speaker actually you would get 6db everytime you double the number of speakers. +3db for the added speaker(s) and +3db from double the power handling. But your right you get +3db everytime you double the speakers that is if you keep the power the same. Won't comment on line array or bessel array as I havn't heard either one.
Bill W.
Previous Topic: What's wrong with your 103E's? Mine have plenty of bass!
Next Topic: Altec 406 specs?
Current Time: Tue Nov 03 16:43:03 CST 2026
