Home » Audio » Speaker » Triple chamber reflex
Triple chamber reflex [message #21957] Fri, 09 May 2008 15:27 Go to next message
Dynavector is currently offline  Dynavector
These look interesting. What are the benefits of double and triple chambers? Are each tuned lower to get more bass extension or is one of them more like a bandpass making the "excitation band" wider?
David
Re: Triple chamber reflex [message #21958 is a reply to message #21957] Sun, 11 May 2008 11:45 Go to previous message
Since no one else has posted, I'll give it a shot, although I have never personally done a multi chambered BR.
In this design, there are three chambers in series. First the smallest chamber resonates, then the combination of the two smallest, finally the entire volume resonates. This means that there are three separate frequencies that the box supplies the majority of the output. If the resonant frequencies are spaced correctly and the tails properly shaped, the resonant gain of the box will be spread over a larger band width than a single chamber BR. The problem is that usually there are sharp valleys between the resonant peaks. I have never been able to model a multi chamber BR that was smooth enough for my tastes. However, valleys are much less noticeable than peaks. Perhaps this particular design works. There is really only one way to tell for sure.
Bob
Previous Topic: The VMPS Neo Ribbon Driver - Anyone Ever Measure One ?
Next Topic: Tuning a speaker port
Current Time: Mon Nov 30 10:51:57 CST 2026
