Home » Audio » Speaker » Smallest Enclosure for DCA 55
Smallest Enclosure for DCA 55 [message #21900] Tue, 06 November 2007 15:50 Go to next message
JAYEM is currently offline  JAYEM
Can anyone advise me about the smallest possible enclosure into which a DCA 5.5 can be fitted and used ?
Sealed ,slotted or ported boxes are all aceptable.
I am willing to give up bass extension and a degree of sensitivity-as you can imagine, the WAF is paramount.
I have a good REL sub-bass speaker, so I can make up the bass.
JAYEM
Re: Smallest Enclosure for DCA 55 [message #21901 is a reply to message #21900] Tue, 06 November 2007 22:36 Go to previous messageGo to next message
YOU could do a small BR. But I'd recommned the PAWO for decent WAF and decent sound.
See my link below for pics & dimensions.
-akhilesh
Re: Smallest Enclosure for DCA 55 [message #21902 is a reply to message #21901] Wed, 07 November 2007 08:31 Go to previous messageGo to next message
Thanks,
The PAWO is certainly on my shortlist, but it seems to me that it is to be used to get a fair amount of bass extension from a smallish enclosure.
I understand that the Jordan 92 can be used in sealed, ported,Mass Loaded andT/L enclosures.
Can the DCA5.5's also be used likewise, or is it just the sound quality that they share with the Jordans?
I am not a tech-savvy person, so explanations will need to be simple.
Thanks
Ok: BAsic BR box for DCA 5.5 (pretty detailed instructions) [message #21903 is a reply to message #21902] Wed, 07 November 2007 10:47 Go to previous messageGo to next message
Detailed instructions on a Bass Reflex box for dca 5.5 driver:
Buy baltic birch (0.75 inches thickness from a local wood store or home depot ) and paste two sheets together, so the thickness is 1.5". Your cabinet maker/carpeneter who buld the box can easily do this.
Then build (or get built) a box, 18 in wide, 18 in high and 12 in deep.
make a round hole in the box, near the bottom, 1.5 inches in diameter.
Leave the hole as is, but make sure it's round! No port pipes needed.
Stain the box as you like and seal the stain.
Mount the driver nearer the top of the box, but still somewhat in the middle of the box.
Put the speaker terminals at the back (parts express sells some good cheap ones).
Make sure the box is well sealed (use caulk) and put some thin carpet on all sides on the inside. Put a deflex pad or something at the back of the driver , on the inner back wall.
Put the speaker on the GROUND, facing slightly up, and listen to it sitting on a couch.
This should get you bass down to about 40 hz and take care of the off axis requirement.
Enjoy!
-akhilesh
Re: Ok: BAsic BR box for DCA 5.5 (pretty detailed instructions) [message #21904 is a reply to message #21903] Wed, 07 November 2007 10:49 Go to previous messageGo to next message
The dimensions given above are for the OUTSIDE of the box, assuming 1.5" thickness (the inside will be about 1 cubic feet).
-akhilesh
Re: Ok: BAsic BR box for DCA 5.5 (pretty detailed instructions) [message #21907 is a reply to message #21904] Wed, 07 November 2007 14:47 Go to previous messageGo to next message
Thanks a lot, Akilesh
I shall be making my cabinets in India.
Baltic Birch is not available there.
My choices are limited to:-
1) Solid wood such as Padauk.
2 ) Architectural Ply-very heavy and dense.
3 ) Commercial ply which is light, cheap and probably full of voids.
4 ) MDF ( Shock,horror)
JAYEM
Re: Ok: BAsic BR box for DCA 5.5 (pretty detailed instructions) [message #21908 is a reply to message #21907] Wed, 07 November 2007 16:37 Go to previous messageGo to next message
Any reasonably dead sounding wood should work.
-akhilesh
Re: Ok: BAsic BR box for DCA 5.5 (pretty detailed instructions) [message #21909 is a reply to message #21907] Wed, 07 November 2007 16:39 Go to previous messageGo to next message
Eric Gonzales is currently offline  Eric Gonzales
post some pics when you're done, jayem
Re: Ok: BAsic BR box for DCA 5.5 (pretty detailed instructions) [message #21910 is a reply to message #21908] Wed, 07 November 2007 17:56 Go to previous messageGo to next message
Thanks,
I'll take it from here
JAYEM
Re: Ok: BAsic BR box for DCA 5.5 (pretty detailed instructions) [message #21911 is a reply to message #21909] Wed, 07 November 2007 17:58 Go to previous messageGo to previous message
Will do,but you will have to wait a feww months till I get back to India and get my carpenter on to the job
JAYEM
Previous Topic: 94 db speaker
Next Topic: Gallos versus DCA
Current Time: Tue Oct 20 21:16:14 CDT 2026
