Home » Audio » Speaker » Fostex f200a fullrange drivers?
Fostex f200a fullrange drivers? [message #21845] Sat, 28 July 2007 16:53 Go to next message
daniel07 is currently offline  daniel07
Hello I am looking at getting a pair of the fostex f200a drivers. I am plaining on putting them in a open baffle. I want the cleanest sound possible and cut it off at 100hz and let a sub take over from there. How does that sound? Has anyone tried this speaker or in a open baffle? How do they sound? Thanks phil
Re: Fostex f200a fullrange drivers? [message #21846 is a reply to message #21845] Sun, 29 July 2007 10:06 Go to previous messageGo to next message
HI Daniel,
I've never heard them, but with a qts of 0.32 you may need a large baffle to go down to 100 hz on these. I think these will probably perform better in a BR box. Just my 2 cents.
thanks
-akhilesh
Re: Fostex f200a fullrange drivers? [message #21847 is a reply to message #21845] Mon, 30 July 2007 05:42 Go to previous messageGo to next message
I have had good luck with the F200A in a TL. This is one Fostex driver that had great bass without forcing it. I seems a shame to waste the bottom end of the F200A by cutting it off at 100 Hz.
Bob
Re: Fostex f200a fullrange drivers? [message #21848 is a reply to message #21845] Mon, 30 July 2007 12:01 Go to previous messageGo to next message
Zeno is currently offline  Zeno
why fostex f200a? why not DCA 5.5? i have a pair of jordan xj92 but after listening to the DCA 5.5 i prefer the DCA 5.5
zeno
Re: Fostex f200a fullrange drivers? [message #21849 is a reply to message #21848] Tue, 31 July 2007 05:16 Go to previous messageGo to next message
The assumption is that we are building a single driver speaker. No sub, no tweeter. That requires that the single driver chosen has a range of 20-20kHz. Well,that's not going to so we do the best we can. I want my speakers to do 40-15kHz or better. In order to get the bottom I need, I need at least a 6" driver, and I find that 8"ers give the best overall balance and punch. Opinions vary, but that's mine.
Bob
6" versus 8" [message #21850 is a reply to message #21849] Fri, 03 August 2007 12:46 Go to previous messageGo to next message
In my experience, 8 inchers have better midbass but suffer from top end rolloff or beaming. I have never heard the F200A but looking at the specs it seems better in this regard. I find, in general, that a 5-6 incher can be more easily made to give proper top end extension and still produce credible bass using the right enclosure/better Xmax, etc.
This is why i like the dca 5.5 design so much, since it does both these things well.
I also like the fostex 6 inch drivers for the same reason, though the dca 5.5 has better bass than those, in the PAWO horn.
-akhilesh
Re: Fostex f200a fullrange drivers? [message #21893 is a reply to message #21847] Tue, 30 October 2007 13:46 Go to previous message
DrD is currently offline  DrD
I would be more inclined to cut off the top ~7KHz, and add the horn tweeter. The upper treble on the F200A in my opinion doesnt do the lower register any service at all. It has a heat that the LE-8 JBL manages to avoid. It is a fun driver though, and a stunning chunk of industrial art~
Previous Topic: Tower speakers
Next Topic: Seen pricing on new Hemp Acoustics coaxials yet?
Current Time: Sat Oct 31 16:12:38 CDT 2026
