Home » Audio » Speaker » Intercom replacement speaker needed
Intercom replacement speaker needed [message #21794] Tue, 13 March 2007 13:20 Go to next message
jim t mcdaniels is currently offline  jim t mcdaniels
Can anyone help with this situation:
I have a nutone home intercom system and one of the speakers voice coil has gone out.
I can't find a replacement speaker, and they want too much $$ for the whole unit that contains the speaker.
I can't find a new speaker, it's a little 3 1/2", 16 ohm speaker. Noone carries 16 ohm..
Is there somewhere I can order one of these?
Can I order a 4 ohm and add a resister in line to one of the connections to make it 16 ohm resistance??
More of these units are probably gonna go out over the years, hopefully I can find an affordable replacement speaker.
Thanks for any help!
Re: Intercom replacement speaker needed [message #21795 is a reply to message #21794] Tue, 13 March 2007 14:12 Go to previous message
I doubt the use of a 4Ω or 8Ω speaker will damage the amplifier in your intercom, so I'd just replace the 16Ω unit with another speaker that would physically fit. I woudn't bother with adding a series resistor, because I don't think the additional current will hurt the amp. If it has a volume control, then just don't turn it all the way up and you'll be fine.
Previous Topic: Rounded Bends vs. Flat Reflectors in Folded Horns
Next Topic: Why Are Some Line Array's So Midrangey And Foreward Sounding ?
Current Time: Mon Nov 30 11:48:43 CST 2026
