Home » Audio » Speaker » Damaged Wizzer Cone
Damaged Wizzer Cone [message #21764] Wed, 10 January 2007 10:46 Go to next message
gfederys is currently offline  gfederys
Hi all, I need to repair a tear in a EV LS8. The tear is about an inch long, fits together tightly, and can be accessed from behind the wizzer cone. I was thinking of mixing some Tightbond with a drop of water and applying it with either a toothpick or a fine needle hypodermic along the crack. Does this sound like it'll work or does someone have a better solution? Thanx in advance for the help.
Don't do that [message #21765 is a reply to message #21764] Thu, 11 January 2007 09:45 Go to previous messageGo to next message
It will form a dried lump & mess up the linearity, becuase of uneven mass distribution.
YOu need something flexible that stays "wet"
Here you go:
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=340-076
-akhilesh
Re: Don't do that [message #21766 is a reply to message #21765] Thu, 11 January 2007 10:10 Go to previous message
As always, you guys are "The Guiding Light". Thanx for your help.
Previous Topic: vintage or new? Polk or ?
Next Topic: Hook up wire?
Current Time: Tue Nov 03 06:00:15 CST 2026
