Home » Audio » Speaker » More info wanted on DCA speaker drivers, and help wanted on 1st horn speakers!
Re: More info wanted on DCA speaker drivers, and help wanted on 1st horn speakers! [message #21738 is a reply to message #21737] Thu, 09 November 2006 21:25 Go to previous messageGo to previous message
If on a tight budget, here is a possible solutioin:
Don't think about biamping (a good crossover costs a few hundred anyway + the cost of the extra sub amp will be a couple hundred). Instead, try out a passively crosssed solution. I'd buy a pair of drivers from parts express (the pioneer foam surround woofers come to mind), put them in a BR box, and cross the entire thing 12 db / octave at around 70 Hz.
Match for efficiencies, you may find that you have to lower the effs of the woofers (a first, eh?) to get a solution that meets your needs.
You could build the BR box so it attaches to the back of the horn or something. I think this solution would also sound very nice.
Previous Topic: Baffle Step Roll-off, electronics crosses, and ARRAYs
Next Topic: Prototype 3 of my homemade OB LA systems are running...
Current Time: Fri Nov 06 07:01:39 CST 2026
