Home » Audio » Speaker » More info wanted on DCA speaker drivers, and help wanted on 1st horn speakers!
Re: More info wanted on DCA speaker drivers, and help wanted on 1st horn speakers! [message #21737 is a reply to message #21736] Wed, 08 November 2006 21:40 Go to previous messageGo to previous message
Cheesehead is currently offline  Cheesehead
The problem with this is that, to put it simply, I can't afford a proper subwoofer. (I'm a student. Go figure.) 300$ is too much, especially considering that I don't need that power.
I'm thinking about using a WC20RC38-s woofer (40$) - although hardly a traditional sub, they can perform well down to 30hz with pretty much no EQ. Combined with a 32w Gainclone amplifier set to double the gain of the PAWO amps, this should provide some pretty decent bass for a very low cost. (I live near Madisound.)
http://www.madisound.com/silverflute.html
Here's a speaker using this exact woofer, or possibly the slightly cheaper non-shielded version.
http://www.tnt-audio.com/casse/jupiter_europa_e.html
I might just build all three gainclone channels into the subwoofer, and use an outboard preamp.
Previous Topic: Baffle Step Roll-off, electronics crosses, and ARRAYs
Next Topic: Prototype 3 of my homemade OB LA systems are running...
Current Time: Fri Nov 06 07:01:24 CST 2026
