Home » Audio » Speaker » More info wanted on DCA speaker drivers, and help wanted on 1st horn speakers!
Re: More info wanted on DCA speaker drivers, and help wanted on 1st horn speakers! [message #21736 is a reply to message #21735] Wed, 08 November 2006 20:56 Go to previous messageGo to previous message
I'd stay away from the ultra cheap subs & most kits. They are not great for musicality (may give good SPLs but not flat curve. )
The best value for the money I know of is hsu research. You can get a used vtf hsu sub on audio groan for about $350-$400. WELL worth it. Dr. Poh Tser Hsu knows what he is doing with regard to subs.
I don't know of any subs for less than that, unless you get a used velodyne. Can't think of anything else in the sub $350 range that would work well.
The dca drivers in a PAWO horn deserve a good sub.
I'd save. Besides, a good sub can be used in other systems as well.
My 2 cents.
Previous Topic: Baffle Step Roll-off, electronics crosses, and ARRAYs
Next Topic: Prototype 3 of my homemade OB LA systems are running...
Current Time: Fri Nov 06 07:01:29 CST 2026
