Home » Audio » Speaker » OPen baffle designs
Good advice [message #21694 is a reply to message #21691] Tue, 29 August 2006 03:30 Go to previous messageGo to previous message
Actually I crossed over (and Eq'd)electronically at 24 dB/oct from 70 Hz to 200 Hz. The higher the crossover the worse the sound and the lower the crossover the more limited the output.
I finally concluded that if you listen primarily to Leslie Olsher and/or small group works that tend to benefit from "polite" levels it's a very good design, easily executed unlike most Lowther horns. But if you want a speaker to do "everything" that isn't the path to the holy grail.
Previous Topic: Is it my imagination .....OR
Next Topic: what are the best small compact speakers you would suggest?
Current Time: Sat Oct 17 05:22:14 CDT 2026
