Audio
Void Filling Foam?
Re: Void Filling Foam?
message #21561
is a reply to
message #21559
Sun, 04 June 2006 19:22
Skip
May 2009
Thanks for the info. I looked at Great Stuff on the
product web site. I sounds like you would want put a small
amount into the speaker, let it cure and then add some more.
Sounds like you get a better cure, and avoid over pressuring
the wood.
Skip
Message index
Void Filling Foam?
By:
Skip
on Sat, 03 June 2006 16:18
By:
Scorey
on Sat, 03 June 2006 22:12
By:
on Sun, 04 June 2006 11:29
By:
Skip
on Sun, 04 June 2006 19:22
By:
gfederys
on Mon, 05 June 2006 05:44
By:
GarMan
on Mon, 05 June 2006 09:45
Thanks All
By:
Skip
on Mon, 05 June 2006 19:25
GPAF Treasure
Mounting an 811 horn
Sun Nov 01 19:08:06 CST 2026
