Home » Audio » General » Blind testing and what I would like to see done...
Re: Definition of DBT [message #2142 is a reply to message #2141] Fri, 26 August 2005 09:34 Go to previous messageGo to previous message
Thanks for bringing that up. The other concern I have and I don't want it to appear confrontational so I will just state simply and honestly this; if you make a distinction between two units, that distinction requires you have a basis of comparison. If that shows a difference then by definition a quality determination must be made. You may say you like both and they are just different; but with a difference by definition there must be good aspects and bad aspects assigned. Otherwise there would be no discernable difference to speak about.
It's a judgement call indicating one is something that the other is not.
Thats a quality descision.
Previous Topic: Tascam 133
Next Topic: Hey Charlie, man are you out there?
Current Time: Tue Nov 03 19:42:39 CST 2026
