Home » Audio » Speaker » Cheap and easy phase plug
Re: Cheap and easy phase plug [message #21415 is a reply to message #21406] Mon, 09 January 2006 13:48 Go to previous messageGo to next message
Ron brady is currently offline  Ron brady
Hi Dave
I recently installed a small tweeter on the 2" pole piece for my Beta 12LT making it a coaxial driver. The tweeter I used is an automotive tweeter made by Lanzar. It is a 1" silk dome tweeter with an spl rating at 96db. It is their DCT model and is a perfect fit on a short piece of pvc pipe attached to the pole piece. I am using it at 9500Hz and above using a 4.3mfd solen cap as a crossover element and nothing more. At $20 per pair it is a great find. They also make a 1" titanium tweeter that has a rating of 96db for about the same price.
Hope this helps.
Ron Brady
Re: Cheap and easy phase plug [message #21416 is a reply to message #21415] Mon, 09 January 2006 16:27 Go to previous message
I'll look into those. Thanks.
Dave
Previous Topic: What measurements matter to audibility?
Next Topic: Ciare HX-201 10" wideband?
Current Time: Fri Nov 13 05:55:24 CST 2026
