Home » Audio » General » Blind testing and what I would like to see done...
obviously a reading problem on your part... [message #2138 is a reply to message #2134] Thu, 25 August 2005 20:17 Go to previous messageGo to previous message
Mr Vinyl is currently offline  Mr Vinyl
Show me where I said "You suggest that if someone cannot tell the difference in a DBT between copper cables and $100/foot silver cables, then DBT is useless."
I said...
"If the above tests show that people can consistently hear differences between speakers, cartridges and even amps and preamp, then this would be a mark for the double blind testers."
I am only suggesting that if people couldn't hear a difference between speakers in a double blind test then maybe the tests are not accurate for this kind of thing. That's all I said. I have no idea how a DBT would come out using speakers. Don't be so combative and try understanding the post before you jump to conclusions.
You say...
"I think that "if people had trouble telling apart even speakers, cartridges and preamps using blind testing, this would help prove the point of view that" there were no audible differences between the things being measured."
So the test must be accurate no matter what the circumstances? So if in a double blind test people could not tell the difference between water and wine then there must be no difference?
Makes sense to me.
Previous Topic: Tascam 133
Next Topic: Hey Charlie, man are you out there?
Current Time: Thu Nov 05 08:15:10 CST 2026
