Home » Audio » Speaker » A little article about a BLH....why go to the trouble.....
Mouth Area and Cut-Off Frequency [message #21251 is a reply to message #21240] Sat, 20 August 2005 14:16 Go to previous messageGo to previous message
Martin is currently offline  Martin
For your mouth area, and assuming only floor reinforcement, I get a lower cut-off frequency of 172.5 Hz. The only way I can get your 86Hz is if I assume the speaker is flush against a side wall also. My guess is that your Hedlund horn is really acting like a TL below 200 Hz and transitions to a horn above this frequency.
I would also speculate that you are probably getting weak bass and could use a BSC circuit to help tame the rising mid and high frequency response of the DX4 driver, this is probably why you are using a sub woofer to help the low end. With a good BSC circuit design, the sub woofer may not always be needed unless you really want to play bass heavy music.
Martin
Previous Topic: Array with Aurum G1 and Extremis?
Next Topic: Bass horn pic
Current Time: Fri Oct 16 14:10:59 CDT 2026
