Home » Audio » Speaker » A little article about a BLH....why go to the trouble.....
| Re: Horns, transmission lines and reflex cabinets [message #21250 is a reply to message #21248] |
Sat, 20 August 2005 06:22   |
Martin
Messages: 220 Registered: May 2009
Master |
When you place Lowther DX4s in tranmission line cabinets, do you need to pad down the upper frequencies or does the cabinet bring up the bass sufficiently to match the upper frequencies so that no equalization is required? In all the designs I have built and measured, you need to pad down the upper frequencies with a correction circuit. The cabinet can be designed to produce bass equal in efficiency to the driver radiating into 2 pi space. However, by placing the enclosure out in a room the baffle step will exist which requires correction. Martin
By: Retsel on Wed, 10 August 2005 13:41
By: Retsel on Thu, 11 August 2005 07:15
By: Retsel on Tue, 16 August 2005 09:44
By: Martin on Tue, 16 August 2005 17:48
By: Retsel on Thu, 18 August 2005 08:08
By: Retsel on Thu, 18 August 2005 09:32
By: Martin on Thu, 18 August 2005 15:37
By: Retsel on Fri, 19 August 2005 08:05
By: Martin on Sat, 20 August 2005 06:22
Mouth Area and Cut-Off Frequency
By: Martin on Sat, 20 August 2005 14:16
Re: Mouth Area and Cut-Off Frequency
By: Retsel on Mon, 22 August 2005 08:31
By: Martin on Thu, 25 August 2005 18:23
By: Retsel on Fri, 26 August 2005 09:17
By: Retsel on Mon, 03 October 2005 10:41
By: Retsel on Mon, 03 October 2005 14:41
By: Chris K on Thu, 18 August 2005 20:29
By: ChrisK on Thu, 18 August 2005 22:17
Maximum SPL charts
Re: A little article about a BLH....why go to the trouble.....
A W-bin!
Re: A W-bin!
Hurt me; hurt me!
Re: Hurt me; hurt me!
You have mail, Bob.
Current Time: Fri Oct 16 15:24:03 CDT 2026
