Home » Audio » General » Retard Question
Retard Question [message #2120] Sat, 20 August 2005 16:44 Go to next message
In simple-simple terms:
If I want to jack up an AC voltage I can use a transformer.
If I want to jack up a DC voltage is my only choice a transistor/valve?
If I want to jack 9 volts to something huge, like 500,000 volts, is the option to cascade transistors?
Re: Retard Question [message #2121 is a reply to message #2120] Sat, 20 August 2005 20:56 Go to previous messageGo to next message
You can generate AC from the DC source, with an oscillator or another form of switching device, then transform it way up with a television flyback transformer or car coil or something similar. Rectify it back with a high voltage rectifier, or possibly a series string of them to get breakdown voltage high enough.
Thanks Wayne [message #2122 is a reply to message #2121] Sun, 21 August 2005 06:58 Go to previous message
I appreciate the response
Previous Topic: Fisher 400
Next Topic: the qts/xmax of Pioneer pim-20a or Lafayette sk98
Current Time: Fri Nov 27 07:57:43 CST 2026
