Home » Audio » Speaker » Why won't a single driver speaker do metal?
Re: Why won't a single driver speaker do metal? [message #21175 is a reply to message #21169] Sun, 07 August 2005 03:01 Go to previous messageGo to previous message
I think the problem to overcome is three-fold, one being upper extension, another being intermoduation and the other being X-Max. The thing I've seen most single drivers do best is mid and highs, which leaves the designer to focus on a cabinet that improves bass response.
But no matter what you do - horn, reflex or transmission line - the bandwidth required is the same. A single driver is required to cover the entire audio band. That means the intermodulation issue is the same cross to bear for each of the three designs. And while excursion is limited at certain frequencies in each of the above mentioned designs, you still need to have displacement to generate bass, and that means excursion.
Previous Topic: interesting auction item
Next Topic: Driver Size Thoughts
Current Time: Tue Oct 20 21:17:25 CDT 2026
