Home » Audio » Speaker » fullrange single driver help please!!
Re: fullrange single driver help please!! [message #21010 is a reply to message #21008] Fri, 10 June 2005 11:33 Go to previous messageGo to previous message
HI Peter,
While I don;t have anywhere near the level of experience or Knowledge MArtin has, I'll trow in some things.
1. I would deifnitely recommend you try MArtin's design for the 206. This is totally passive.
As some one who has tried active & passive crossovers, I would say I prefer active, but that's only for my setup. In the right setup, passive can be as good.
PArametric equalizers are WAYY better than graphic ones for almost any application. For your applications, a prametric equalizer would work, but not a graphic one.
I wold recommned that you try the passive eq that MArtin does, and keep your signal path simple to start with. If you are just using one driverm, then there is no choice but to use passive components or a parametric EQ.
-akhilesh
Previous Topic: Axon 8-12 array
Next Topic: Tangband W3-871 fullrange
Current Time: Mon Sep 14 01:42:58 CDT 2026
