Home » Audio » Speaker » Midrange smear in transmission lines
Re: Designing a TL [message #20964 is a reply to message #20955] Thu, 02 June 2005 10:32 Go to previous messageGo to previous message
Martin is currently offline  Martin
Bob,
You wrote :
"If the Qts is in the low 0.20's or lower, the driver belongs in a back horn. Performance in a quarter-wave pipe will be disappointing."
My latest thinking on these "back-loaded horn" designs is that almost all of them are really TL's for the lowest frquencies. If you look at the mouth area, multiply it by between 2 and 8 depending on room placement, you will find that the horn cut-off frequency is probably much higher then the designs claimed low end performance. So the enlcosure exhibits TL responses for two or three modes and then transitions to a horn like response. Compare Nelson Pass's Kleinhorn with the Fostex designs. There is nothing wrong with this approach and I am using it in my latest design.
Martin
Previous Topic: Anyone have prices for the new Iconic coaxials?
Next Topic: thanks for the info and help
Current Time: Tue Nov 03 19:44:37 CST 2026
