Home » Audio » Speaker » voight pipe plans for 206 Fostex
voight pipe plans for 206 Fostex [message #20896] Mon, 09 May 2005 10:14 Go to next message
I guess the only way I'll satisfy my questions as to how the FE206e's will sound in the Voight pipe design is to build them---I have a good plan in a 6" driver but could use some spec's for the 8 inch--I have talked to Brad ( cabinet builder) about using some solid hardwoods over plys---we'll about that---anyone seen a 8" plan?? Jim
Re: voight pipe plans for 206 Fostex [message #20897 is a reply to message #20896] Mon, 09 May 2005 11:03 Go to previous messageGo to next message
The only plan I have seen is at the link below. It seems to be about the same size as your current pipes. It uses the 207 instead of the 206. I have been considering building another set of Voigt pipes for my Audio Nirvana 8" drivers, whose T/S parameters are close to the 206. I will make them in a slightly larger cross section, dictated by the 11-1/4" width of the mdf boards I get from my lumber source. But hardwood would look really nice.
Re: voight pipe plans for 206 Fostex [message #20899 is a reply to message #20897] Mon, 09 May 2005 16:54 Go to previous messageGo to next message
Well there is a major diffierence in Qts. Some added series resistance will help (4-6 ohms). Be sure to use at least 10 watt non inductive resistors. I had my original 206es in a break in, folded TQWT and it took the added series resistance to get an acceptable bass response.
ron
Good Thing to Know [message #20900 is a reply to message #20899] Mon, 09 May 2005 18:03 Go to previous messageGo to next message
If you must use series resistance I wounder if you could parallel the resistor with a 1.5mH inductor to create a baffle step compensation network?
Re: Good Thing to Know [message #20901 is a reply to message #20900] Mon, 09 May 2005 20:50 Go to previous messageGo to next message
Sorry, Fred. That won't work. The series resistor is just to raise the effective Qts of the driver up to the level needed for a Voigt Pipe. The BSC step filter comes after that.
My personal dislike for the Voigt pipe is well known, particularly the Lowther Club of Norway TQWT that one of the links is really pointing at. But if you must, use the FE207E rather than the FE206E. You will have a much better chance as a decent sound.
Bob
Opinions on Voigt Pipe [message #20902 is a reply to message #20901] Tue, 10 May 2005 12:51 Go to previous messageGo to next message
Hi Bob,
I'm interested in hearing your opinion of Voigt Pipes. Do you have a link to it, or can you provide a 60 sec tour?
thanks,
gcl.
Re: Opinions on Voigt Pipe [message #20903 is a reply to message #20902] Tue, 10 May 2005 14:10 Go to previous messageGo to next message
This link is what I discovered about the classic Voigt pipe, which BTW, is not wat Paul Voigt had intended. But that's another story.
GM points out, quite correctly, that the zero So pipe does have a use with certian drivers, but in general you must give up bass extension for mid-bass smoothness. The classic VP with extension below Fs is fatally flawed.
Bob
Re: voight pipe plans for 206 Fostex [message #20904 is a reply to message #20896] Tue, 10 May 2005 14:18 Go to previous messageGo to next message
zobsky is currently offline  zobsky
if you're having a cabinet builder build it, why not just go for a back horn. Ron's design seems to be liked.
Another interesting post I came across today on AA using the 206 E (though in a 2 way) at http://www.audioasylum.com/forums/hug/messages/88224.html
cheers, nice meeting you a few weeks ago at GPAF.
Voigt Pipe Alternative for FE-206 [message #20905 is a reply to message #20896] Tue, 10 May 2005 19:43 Go to previous messageGo to next message
The only advantage to a voigt pipe appears to be its simplicity - it's very easy to build one. In contrast, all the back loaded horn enclosure plans I have seen for the FE-166 and 206 would require some woodworking skills and seem to be very labor intensive. I was wondering if there's a simpler plan, possibly like the BK-16 folded horn that Madisound offers as a flat pack kit for $98?
Re: voight pipe plans for 206 Fostex [message #20908 is a reply to message #20904] Wed, 11 May 2005 08:25 Go to previous messageGo to previous message
Can you shoot me an de-mail with rons back loaded horn plans---I'm not up on this design I guess Jim
Previous Topic: Deep Model 16 Loudpeaker system
Next Topic: Component Values for ELF1.5 ?
Current Time: Fri Nov 13 07:50:13 CST 2026
