Home » Audio » Speaker » Ideal freq. to tune Fostex 206 cabinet
206 in 45L cab tuning suggestions [message #20859 is a reply to message #20858] Thu, 21 April 2005 23:18 Go to previous messageGo to previous message
ronbrady is currently offline  ronbrady
Hi Pete
I ran a quick simulation on WinISD for you for the 206E and it looks like it really doesn't want to fit a 45liter cabinet smoothly without quite a lot of series resistance to raise the qts. from .18 to .40. I have tried this trick in the past and it works but I think that it robs some of the detail from the mids and highs but it should produce good bass. My results are a port tuning of 40Hz with a 3"ID tube 5.15" long.This will give a port velocity of Mach 0.15 . This alignment will require at least a 6 Ohm audio grade resistor in series with the driver.
You should be happy with this combination unless you are expecting to use a low powered amplifier at which case your efficiency will suffer terribly especially if you intend to install a baffle-step correction circuit.
Good luck with your project
Ron Brady
Previous Topic: How does Alter Model 19's compare to today's offerings?
Next Topic: blending point source and line array
Current Time: Fri Nov 13 08:14:58 CST 2026
