Home » Audio » Speaker » Fostex 6.5 vs. 8
Fostex 6.5 vs. 8 [message #20812] Mon, 11 April 2005 12:33 Go to next message
Peter Swartz is currently offline  Peter Swartz
I'm debating wheather to go 6.5 or 8. I'm interested in a small
approx. .75 cu. ft. enclosure.
First and foremost is sound quality. I'm not sure what are the optimal dimensions or interior volume for these two drivers and is it mainly the volume or do the demensions of the volume play a big role? How about size and length of front port? Thanks! Pete
Re: Fostex 6.5 vs. 8 [message #20821 is a reply to message #20812] Wed, 13 April 2005 12:45 Go to previous message
I'd go with the 6.5: it has a flatter response. I'd also use a sub. IF you are going pure single driver, then a 206 with a contouring circuit will probbaly be better.
My 2 cents.
thanks
-akhilesh
Previous Topic: 6.5 fullrange driver choices
Next Topic: tube amps and vibrations
Current Time: Fri Nov 06 04:43:04 CST 2026
