Home » Audio » Speaker » 6.5 fullrange driver choices
6.5 fullrange driver choices [message #20808] Mon, 11 April 2005 10:17 Go to next message
Peter Swartz is currently offline  Peter Swartz
Hello, I'm trying to learn which 6.5 full range driver sounds best.
I interested in a smallish near field front ported cabinet. Any suggetions? Fostex 166 or audio nirvana? Thanks, Pete
Re: 6.5 fullrange driver choices [message #20811 is a reply to message #20808] Mon, 11 April 2005 12:19 Go to previous messageGo to next message
Fostex 166 for back horns, Fostex 167 for resonant cabinets -- BR or MLTL. 168E signa has a following -- probably best in a back horn. Audio Nirvana is too new to tell, keep watching for posts. There are a lot of other full-range drivers out there, primarily Euopean, so you will just have to keep reading.
IMO-YMMV
Bob
Re: 6.5 fullrange driver choices [message #20818 is a reply to message #20808] Tue, 12 April 2005 15:13 Go to previous messageGo to next message
Hi Peter,
I made a pair of corner surrounds using Fostex 167's. The boxes are about 1 cu ft. When used as mains, they don't sound 1/2 2 bad as
long as the loudness is turned on. Without it, they are a little
wimpy for the fairly big room. The ports is the back into the corners
does make a difference (more bass), so I can't say how they'd be in a
regular ported box. I also made a pair of TQWT's with Fostex 207's.
Now those thing make some real bass. Its not super clear necessarily, but there's lots of it.
Chris
Re: 6.5 fullrange driver choices [message #20820 is a reply to message #20808] Wed, 13 April 2005 12:44 Go to previous message
I heard the Fostex Fe166 i think, in a voigt pipe at Jim Denton's house. I was very impressed with its response, esp above 100 HZ.
It seems quite flat, much more so than the FE206E. I am assuming you will use some kind of sub for this?
thnaks
-akhilesh
Previous Topic: OT acoustic trap - help
Next Topic: Fostex 6.5 vs. 8
Current Time: Fri Nov 06 04:15:01 CST 2026
