Home » Audio » Speaker » anyone know build this horn?
Re: anyone know build this horn? [message #20612 is a reply to message #20580] Sat, 15 January 2005 14:06 Go to previous messageGo to previous message
I would try by cutting out the two sax-looking sides in plywood.
I'd use 1X3 or similar tacked between the sides at intervals to maintain spacing: maybe make them permanent through judicious placement.
I'd then form the inside and outside curves with 3/8" bending Meranti, and then veneer over that with Band-It or similar.
I've done something like it before. The problem was that the thin edges of the sides shouldn't 90 degrees to the flat because when you tilt the sides inward the edge surfaces are not co-planer. A little creativity in sawing out the sides and beveling the edges is necessary (along with some filler
Previous Topic: Readers in the EU
Next Topic: 6.5" Woofer
Current Time: Fri Nov 13 08:54:46 CST 2026
