Home » Audio » Speaker » fostex rear loaded horn design
Re: fostex rear loaded horn design [message #20609 is a reply to message #20601] Thu, 13 January 2005 13:07 Go to previous message
robertG is currently offline  robertG
TAD drivers are way too expensive for me! But I would love to compare these to some exotic Fostex drivers (T925).
You are right about the fact that it's difficult to get a flat response with that kind of crossover. On the other hand, placement is the key to balanced sound. Both FR and ST are very directive and output drops quite a bit off-axis (almost 20DB @ 30 deg. @ 20 kHz for the ST), so with proper placement (or misplacement), it's still possible to get great sound without using resistors and/or radical Xover slopes. I mean, with the ST sitting on top, it's possible to have a slight toe-in for the ST and no toe-in for the FR driver.
Previous Topic: CORAL Flat 8A drivers on open baffles
Next Topic: Hi-Efficiency vs Lo-Efficiency Speakers
Current Time: Fri Nov 06 01:37:49 CST 2026
