Home » Audio » Speaker » correction filter for Fostex fe206e in a Jeriko
Re: correction filter for Fostex fe206e in a Jeriko [message #20585 is a reply to message #20584] Fri, 07 January 2005 09:49 Go to previous messageGo to previous message
Kane is currently offline  Kane
Hi there!
I will take pics. The supertweeter consept i do like. Do you have any tips reg. enclosures? i looked up some tweeters from Vifa at: http://www.mamut.com/controls/shop/shops/1/standardplist.asp?wwwalias=dynabel&subgid=1&gid=10
Any suggestions? the spl on the affordable ones is not to effective but there may be a spl boost in a enclosure? I do not have so much knowlege about these things. I have only builded some bassreflex enclosures and som crossover uppgrading before. This Jericho plan i will put together(with some help from my father, who is a furniture builder by profession) as close to the original plan as possible. I will not try to uppgrade its original volum/length and i use the 19mm MDF as the original. But i will add dubble sides and back and fill the empty spaces with sand + experimenting with stuffing.
I´m not shure if the 19mm frontbaffel is thick enough? Do you have an opinion on that? Can i doubble the front too without doing something wrong to the performance? Maybe make the innerplate a bit wider and carve the circle edge.
Well, it´s really interessting and its easy to get stoked over the consept of speakerbuilding.
Later!
Kane
Previous Topic: Choosing array, please help...
Next Topic: Favorite flavors
Current Time: Sun Nov 01 03:29:29 CST 2026
