Home » Audio » Speaker » Push-Pull horns
Re: Push-Pull horns [message #20326 is a reply to message #20324] Sun, 29 August 2004 15:47 Go to previous messageGo to previous message
GM is currently offline  GM
With an uncorrected mass corner around 433Hz, this is way too high for me, so I guess it's a 'different strokes for different folks' situation.
FR tech forum gallery?
Anyway, if you plot out what I posted you'll see that until you get near the mouth of the full size horn, which you wouldn't since the cutoff would be at a much higher frequency, the expansion is conical enough that I'd bet dollars to donuts you couldn't hear the difference outdoors, much less in a typical room.
GM
Previous Topic: New: First Watt amplifiers by Nelson Pass
Next Topic: Line array with single ribbon tweeter
Current Time: Fri Oct 16 20:29:19 CDT 2026
