Home » Audio » Speaker » Push-Pull horns
Re: Push-Pull horns [message #20315 is a reply to message #20314] Fri, 27 August 2004 10:42 Go to previous messageGo to previous message
GM is currently offline  GM
>Extended HF down the back horn is OK.
If the 'XO' point is kept low enough, I agree, but I've experimented enough with BLs that above ~250Hz (some say as low as 100Hz) I find the comb filtering unacceptable, so as always YMMV.
>The back horn throat chamber (LP acoustic filter)is best eliminated - this removes the nasty looking peaks (phase inversions?) shown by HornResponse - which even if well down, must surely be heard full level from the front.
Hmm, if you design the horn properly, the filter doesn't cause this due to the first section of the horn damping it. I assume that either by design/experimentation/blind luck yours works due to having the ~correct first section that is in effect the LP filter.
GM
Previous Topic: New: First Watt amplifiers by Nelson Pass
Next Topic: Line array with single ribbon tweeter
Current Time: Fri Oct 16 18:18:57 CDT 2026
