Home » Audio » Speaker » Buschhorn with visaton frs 8
Re: Buschhorn with visaton frs 8 [message #20069 is a reply to message #20068] Mon, 07 June 2004 13:11 Go to previous messageGo to previous message
mato is currently offline  mato
You are maybe right, but buschhorn was designed for this driver and people use it with success. The next reason for building this horn is that it is suitable for some other drivers, for example Vifa 10BGS which looks very good, so later I can replace the visaton driver with better one.
anyway thanks for your reply Mato
Previous Topic: Stupidity Exposed! Ignorance Revealed!
Next Topic: How close can you sit to a frontloaded bass horn without compromise?
Current Time: Fri Nov 06 01:09:06 CST 2026
