Home » Audio » Speaker » Buschhorn with visaton frs 8
Buschhorn with visaton frs 8 [message #20065] Sun, 06 June 2004 02:50 Go to next message
mato is currently offline  mato
Has somebody tried this combination (buschhorn + visaton frs 8)? I want to try some cheap project just for fun and this looks very good for the price.
I foud these types of buschhorn:
http://hometown.aol.de/hphinder/homepage/
http://www.speaker-online.de/bauen/bhorn.htm
Which one is better for this driver?
Would this works with some other drivers? Maybye later I replace the visaton driver with some fostex or supravox.
Thanks Mato
Re: Buschhorn with visaton frs 8 [message #20066 is a reply to message #20065] Sun, 06 June 2004 20:35 Go to previous messageGo to next message
HI,
Do you have the T/S paramters for this driver?
thanx
-akhilesh
Re: Buschhorn with visaton frs 8 [message #20067 is a reply to message #20066] Mon, 07 June 2004 00:34 Go to previous messageGo to next message
Here you can find T/S parametres:
http://www.visaton.com/english/artikel/art_261.htm
What do you think?
Thanks Mato
Re: Buschhorn with visaton frs 8 [message #20068 is a reply to message #20067] Mon, 07 June 2004 12:43 Go to previous messageGo to next message
HI MAto,
Givne the low range is 100HZ, IMHO it may not make sense to build a major cabinet for this. Try a small sealed box cabinet, and biamp it below 100 HZ. That will probbaly give you decent results.
Just my 2 cents.
-akhilesh
Re: Buschhorn with visaton frs 8 [message #20069 is a reply to message #20068] Mon, 07 June 2004 13:11 Go to previous messageGo to next message
You are maybe right, but buschhorn was designed for this driver and people use it with success. The next reason for building this horn is that it is suitable for some other drivers, for example Vifa 10BGS which looks very good, so later I can replace the visaton driver with better one.
anyway thanks for your reply Mato
Re: Buschhorn with visaton frs 8 [message #20070 is a reply to message #20069] Mon, 07 June 2004 17:32 Go to previous message
Good luck! It would be great if you could let us know your feedback after building this...have fun with it!
-akhilesh
Previous Topic: Stupidity Exposed! Ignorance Revealed!
Next Topic: How close can you sit to a frontloaded bass horn without compromise?
Current Time: Fri Nov 06 00:24:26 CST 2026
