Home » Audio » Speaker » speaker positioning
Re: speaker positioning [message #19897 is a reply to message #19896] Tue, 30 March 2004 06:39 Go to previous message
YVW.If you look at the FR curve you will see a near flat line at a 30 deg angle off axis.I never run any notch filters in the pipes as it kills the dynamics, but i do run 8 ohm series resistance to up the Qes. The horn is a different matter as with the extreem range and pumped up lower the FR is excellent without anything in the signal path.There is no comparasion between the horn and the pipe the horn gives extreem dynamics with SLAM and an extreem tight FAST bass.Next project is to build a set of horns (the one i built is a prototype out of MDF) and i am going to make a case to enclose the gainclone and P/S into a single cab.
ron
Previous Topic: audio meeting
Next Topic: High Efficiency and Amplification Explained
Current Time: Mon Oct 05 14:27:22 CDT 2026
