Home » Audio » Speaker » Cool article on TNT-audio by a single driver nut...Thanx Martin!
Re: Cool article on TNT-audio by a single driver nut...Thanx Martin! [message #19784 is a reply to message #19782] Fri, 20 February 2004 10:32 Go to previous messageGo to previous message
Martin is currently offline  Martin
Hi Jim,
I would be happy to look at whatever calculations you make w.r.t. the filter. You can post them here or e-mail me directly.
If you want to easily remove the filter from the network, all you need to do it pull out the resistor and put in a short piece of speaker wire effectively by-passing the inductor. Might save you the cost off a switch. Either way would work well.
Martin
Previous Topic: Check this out!
Next Topic: series, parallel and speaker sensitivity
Current Time: Sun Oct 18 10:45:23 CDT 2026
