Home » Audio » Speaker » Cool article on TNT-audio by a single driver nut...Thanx Martin!
Re: Cool article on TNT-audio by a single driver nut...Thanx Martin! [message #19782 is a reply to message #19769] Fri, 20 February 2004 09:19 Go to previous messageGo to previous message
Martin---I'm up for the experiment!---I have copied the last post taht gave the formula for building the filter---I'm building it to install in your "Lowther" box and will install a 6" port tube as you mentioned----if it's not too much I may run the calulations I come up with by you as this is my first shot at building a filter----my idea is to install a switch so I can turn the filter on and off---and to be able to do a listening test as Akhilesh and I have been having this discussion of what the filter will or will not do---- Jim PS hope to have boxes glued up by Saturday---going to install the FE 206e in them and have a go with them "unfiltered"
Previous Topic: Check this out!
Next Topic: series, parallel and speaker sensitivity
Current Time: Wed Nov 18 16:44:34 CST 2026
