Home » Audio » General » Upcoming Events
Drywall cornerbead. [message #1971 is a reply to message #1970] Mon, 04 July 2005 22:59 Go to previous messageGo to previous message
Poindexter is currently offline  Poindexter
Okay, I now grok on the fact that you guys are my peers in audio smallbiz, but not necessarily in construction.  Cornerbead is a drywall (sheetrock) accessory.  It's what's used to define outside corners in normal interior construction.  It's a resillient, slightly flexible plastic outside 90° channel moulding that is put on the corners of your home to define the edge of that vertical corner.
If you already know what you're looking for, you can go to HomeDespot and save a dime a stick.  I (shamefully) do.  If you don't, look in your local Yellow Pages for drywall (sheetrock) places, and go there.  Tell the girl at the counter, 'I want four sticks of regular plastic cornerbead.'  If you spend more than five clams, post me and I shall reimburse.  By the way, this is also the place to get 1" and 1½" styrofoam sheets 2' x 4' at the best price.  This is where I get the stuff, and cut up on my saw to fit the box.
Once you do this, you can of course then go to HomeDespot and save a dime; but like me you will probably go back to the drywall place to repeat, both for your industrial ethos, and to flirt with the sheetrock girl     :^)
Serious, in gold-plated Maui, the stuff is $1.08 / stick (8').
Prosper,
E.
Previous Topic: New copy protection
Next Topic: Beam Echo Model SPA-21
Current Time: Sun Nov 29 05:40:44 CST 2026
