Home » Audio » Speaker » DE250\H100 is a nice combo..
DE250\H100 is a nice combo.. [message #19599] Sun, 22 February 2009 10:11 Go to next message
Scholl is currently offline  Scholl
Hi all,
Just wanted to share some info on a nice afordable, easy to use drive\horn combo using the DE250 with the RCF H100. It works nice and smooth with the crossover Wayne cooked up but lower the 6.8UF cap to 2.3 and just use an L-Pad for level matching. That's all I'm measuring 2 db down at 10Khz reference 4Khz so EQ is not needed for most people.
That's all.
Later,
Scott
Re: DE250\H100 is a nice combo.. [message #19600 is a reply to message #19599] Mon, 23 February 2009 13:20 Go to previous messageGo to next message
Looks like a nice little horn. Looks a lot like an H290, to tell the truth, but with a taller mouth and vertical pattern. What does the throat look like? Does it have a diffraction slot like the 2370 or is it smoothly radiused like the H290?
Re: DE250\H100 is a nice combo.. [message #19601 is a reply to message #19600] Mon, 23 February 2009 19:02 Go to previous messageGo to next message
Hi Wayne,
I'ts smooth radiused. For 28.00 from Speakers Plus it's well worth a shot.
Later.
Re: DE250\H100 is a nice combo.. [message #19602 is a reply to message #19601] Mon, 23 February 2009 20:40 Go to previous messageGo to next message
Yeah, cool! Sounds like an H290 with taller vertical pattern at HF.
Re: DE250\H100 is a nice combo.. [message #19604 is a reply to message #19599] Tue, 17 March 2009 19:51 Go to previous message
ttan98 is currently offline  ttan98
I like to confirm what Scott has found, currently I am using this combo, De250 and RCF100 in a bass reflex config., no equalization is required but for those you are perdantic some equalization maybe necessary. I use DCX2496 so I can apply some equalization.
For those you are on tight budget this combo gives very good value for money at the same time sound excellent.
Previous Topic: Tandberg Tuner 3001
Next Topic: new Cardersound Madisons at home
Current Time: Sun Nov 15 05:30:53 CST 2026
