Home » Audio » Speaker » Help with crossover: Bipole surround speaker
Re: Help with crossover: Bipole surround speaker [message #19576 is a reply to message #19575] Mon, 06 October 2008 11:55 Go to previous messageGo to previous message
The issue is caused by interactions between drivers and the nulls and lobes produced. A dipole uses this very process to introduce directivity. Opposing phase on each side of the dipole form front and back lobes with side nulls where the two opposite phases cancel.
Other sound sources will interact too, making lobes and nulls of their own. The issue is essentially one of path length. Where path lengths between sound sources are equal, sound combines constructively. As you move in a direction that makes one sound source closer than the other, you eventually may cross a point where conbination is destructive, forming a null. The wave interaction is constructive as long as the difference is less than 1/4λ, but once it nears 1/2λ, the interaction becomes destructive. So in the room, there are pockets of energy lobes and some dead spots, called nulls. The position of these lobes and nulls is set by driver positions and phase.
Previous Topic: Design Stage : a 4-way system
Next Topic: Vifa DQ25SC16-04
Current Time: Sun Nov 08 20:47:59 CST 2026
