Home » Audio » Speaker » Design Stage : a 4-way system
Design Stage : a 4-way system [message #19565] Sun, 21 September 2008 11:23 Go to previous message
Scott L is currently offline  Scott L
An open invitation for those of you familair with building a 4 way system. I'd like to hear your thoughts.
My concern is the lowest x-over frequency. Right now, 60 Hz is the choice.
Below 60 Hz will ultimately be infinite baffle bass. No concern there. Where I am purplexed at is my choice of mid-bass. I was leaning towards building a reaction cancelling mid bass horn; I want the impressive dynamic slam of a horn system. Obviously, a problem is that at 60 hz a horn would have to be quite large. Actually, I can make the mouth exit size large enough, it's the length required that bothers me. If I move the x-over frequency to 80, I'm afraid I will be feeding too much of the "slam" range to the subs. My other alternative is to scrap the mid horn idea, and to replace it with 4x 12" pro drivers for mid-bass (per channel).
Just for reference, the other two crossover frequencies will be 250 and 3K.
All active system.
Thanks.
Previous Topic: BMS 2193 horn?
Next Topic: Help with crossover: Bipole surround speaker
Current Time: Sun Nov 08 20:31:36 CST 2026
