Home » Audio » Speaker » midhorn seven
midhorn seven [message #19563] Wed, 06 August 2008 18:03 Go to next message
Paolo is currently offline  Paolo
Hi Wayne.im working aroun the midhorn sevenPI and is possible to turn the square throat into a round throat.If yes how the diameter?
thank you
Re: midhorn seven [message #19564 is a reply to message #19563] Thu, 07 August 2008 14:31 Go to previous message
Adrian Mack did a horn like that and its response looked pretty good. I chose a square throat because I could match the flare pieces nicely. But either way, there are path length differences that chew up some of the upper frequencies.
My thinking was if I used a square thoat, the flare transition would be pure. The path length differences are within the compression chamber, but without a phase plug, there are path length differences using any throat shape. The compression chamber forms a low-pass filter, and the path length issues add to that. It becomes a variable, where cone and dust cover size and shape affect the response. This set of variables is hard to model without FEA, so you pretty much have to build and test. Every model of driver will be different.
Previous Topic: Speaker Output (volume)
Next Topic: Arrays in the time domain
Current Time: Thu Nov 05 04:25:54 CST 2026
