Home » Audio » Speaker » Tuning a speaker port
Tuning a speaker port [message #19508] Sun, 11 May 2008 23:12 Go to next message
Peter Swartz is currently offline  Peter Swartz
Hello, I've got a pair of custom speakers, Fostex 206E's in a ported cabinet. The port currently is just a three inch hole in the front baffle which is 1 3/4" thick.
I designed the cabinet with spec's from fostex to have a 40 liter volume.
I was just thinking of taking the speakers another level and to experiment with inserting a port tube maybe 3" to 6" in the hole. I was just wondering if there is an easy way to determine which measurement would work best other than the obvious of just listening to the bass.
Any suggestions would be appreciated.
Thanks, Pete
Re: Tuning a speaker port [message #19509 is a reply to message #19508] Mon, 12 May 2008 14:45 Go to previous messageGo to next message
I would suggest buying one of these and tuning the cabinet with it:
Re: Tuning a speaker port [message #19510 is a reply to message #19508] Mon, 12 May 2008 23:00 Go to previous message
Thanks Wayne, You Rock! Your always there. Pete
Previous Topic: Triple chamber reflex
Next Topic: So I went ahead and built them. . .
Current Time: Mon Nov 30 11:04:43 CST 2026
