Home » Audio » Speaker » Bass Horn with & without Rubber Throat
Re: Bass Horn with & without Rubber Throat [message #19497 is a reply to message #19496] Tue, 22 April 2008 14:27 Go to previous messageGo to previous message
WithTarragon is currently offline  WithTarragon
Thanks for your thoughts.
I am going through the Hornresp process, but I did not know whether it would be sensitive to rubber throat "issues". I will give it a try. When folks discuss rubber throats they usually refer to Olson's book where he offers suggested formulae for horns that are composed of multiple sections in a piece meal fashion (the end of the 1st section serves as the throat of the next section etc), but that is not actually what is going on in a rubber throat configuration.
Conceptually I am wondering if the rubber throat section is acting like a chamber (after the throat) that happens to have a tapered flare). I believe that such chambers were sometimes used to effectively low pass filter the output. However I am going off-track in my speculations...
Anyhow I will give it a shot.
-Thanks
Previous Topic: Which Speaker?!?
Next Topic: BG Neo10 Availability
Current Time: Thu Nov 05 09:00:19 CST 2026
