Home » Audio » Speaker » JBL 2240H for midbass duty
JBL 2240H for midbass duty [message #19461] Mon, 17 March 2008 11:55 Go to next message
spkrman57
I was just wondering if anyone has used the JBL 2240H 18" driver for midbass duty similiar to how the 2226 is used in the 4 pi-pro series?
According to winisd I have come up with 5 cubic ft box tuned to 50hz for a -3 db @ 52hz.
If anyone can comment on this I would appreciate it!
Response down to approx 50hz would be required!
Regards, Ron
Re: JBL 2240H for midbass duty [message #19462 is a reply to message #19461] Mon, 17 March 2008 13:51 Go to previous messageGo to next message
The only problem I see is you'd have to lower the x-over freq. where it crosses over to the midrange, for proper DI matching between the 18 and midrange.
Re: JBL 2240H for midbass duty [message #19463 is a reply to message #19462] Tue, 18 March 2008 13:31 Go to previous message
spkrman57
Appreciate the info on the Di factor and crossover level. I already have that factored in the process.
What I was looking for is to see if anyone has tried a different box/tuning with this driver, and what the results were.
These will most likely be used in a pair of JBL L200 cabs and used in corners for further room reinforcement.
Ron
Previous Topic: Re: smoothing Zobel? tick but not if result is less than 91db/w!
Next Topic: ? ART Array VS Zaph's BAMTM
Current Time: Fri Oct 16 15:21:25 CDT 2026
