Home » Audio » Speaker » Experiment, Insights pls?
Experiment, Insights pls? [message #19447] Thu, 21 February 2008 18:28 Go to previous message
Barry is currently offline  Barry
Any insights would be helpful.
Placed Delta 12LF in 5.1cu ft. Tuned 40Hz. Supposed f3 35Hz.
Near identical twin.
Place Delta 12LF in 5.1cu ft. Made pathway with just a little expansion from driver to near port area (but not too close).
Sounded best when tuned to 35Hz. Perhaps -3 at 30Hz.
Beginning of pathway on 13 inch width interior was set 6.25 inches back so no real compression there IMO.
Purpose of experiment was to see if lower -3 was possible by reducing Fs of driver by having a pathway inside (but open to full width prior to port.
Observations:
It sounds pretty good I think. Seems to have reduced fs of driver by 5Hz.
Seems to go lower but less punchy. Making it sound just a little less loud.
Did try tuning the one without the pathway a little lower and then it did not sound good.
No increase of volume from "inside of speaker horn" at least not with the size of port chosen.
Questions:
Should this not have produced some possible phase problems?
Maybe there is an I'm not hearing it yet?
Maybe what I hear as punchy in the one without pathway is the way is should be and the other is a phase issue on the one with the pathway?
Is there a better way to reduce fs and get a speaker to go lower in a given size box? (one that does not infringe on the patents of others)
Any input would be appreciated.
Barry
Previous Topic: Beta 8A in a 2-way
Next Topic: Speakers to TV
Current Time: Wed Nov 04 05:09:52 CST 2026
