Home » Audio » Speaker » Honey, how much do you looooove me?
Honey, how much do you looooove me? [message #19325] Thu, 19 July 2007 14:27 Go to next message
Saw these on da 'bay. Seriously, how hard would it be build one?
Re: Honey, how much do you looooove me? [message #19328 is a reply to message #19325] Fri, 20 July 2007 13:38 Go to previous messageGo to next message
Just like any other large format basshorn, it just takes a lot of wood, some time to build and some cahones to lift the thing when it's done.
Did you ever see this picture of one of those horns on a Volkswagen Bug?
Re: Honey, how much do you looooove me? [message #19337 is a reply to message #19328] Fri, 27 July 2007 15:50 Go to previous messageGo to next message
DMoore is currently offline  DMoore
Seems to me that a full-size straight bass horn is probably the easiest to design and build. Not taking into account any bending, bracing, mounting, etc.
...And completely ignoring logistics and ALL OTHER CONSIDERATIONS, including "Honey", of course.
Dana
Re: Honey, how much do you looooove me? [message #19339 is a reply to message #19337] Sun, 29 July 2007 12:55 Go to previous messageGo to next message
That's true. A straight basshorn is easy to design. Might be hard to setup and use though.
Re: Honey, how much do you looooove me? [message #19352 is a reply to message #19339] Thu, 30 August 2007 10:18 Go to previous messageGo to next message
willyable is currently offline  willyable
A basshorn is nothing. I watched my best buddy put one together and it was breezy easy. Even the setup was simple. Not as hard as it seems.
Re: Honey, how much do you looooove me? [message #19353 is a reply to message #19352] Thu, 30 August 2007 13:58 Go to previous message
I'm familiar with basshorns. What I was refering to was a straight basshorn, which would be necessarily long. Most basshorns are folded, so the longest cabinet dimensions are kept within a few feet.
Previous Topic: cloth on satellite speakers. ALSO, placment of susbwoofer
Next Topic: Which amp Should i get
Current Time: Mon Nov 16 07:09:23 CST 2026
