Home » Audio » Speaker » Relationship Between X Max And Efficiency Questions
Relationship Between X Max And Efficiency Questions [message #19273] Sat, 09 June 2007 00:27 Go to previous message
Ka7niq is currently offline  Ka7niq
I built some subwoofers, each using an 85 db efficient 15 inch driver capable of 28 mm X Max.
They are in a 9.5 cu ft sealed box, and 3 db down at 22 hz w/o room gain/
They are corner mounted in seperate enclosures.
I have some Dayton 15 inch drivers with 92 DB efficiency, but only 8.5 mm X Max.
I could use em in this box sealed, 3 db would be 32 hz, OR ported they will go right down to 20 hz with 2 - 4" ports 6" long
Box tuning will be 20.49 hz
The current 85 db woofers draw too much power, and make my lights dim as my big amps struggle to feed the power hungry bastards.
They do rattle the room, but do not play loud enough for the bass impact I want.
What in your opinion will I gain, or lose by putting the Dayton drivers in the boxes.
The Daytons are 7 db more efficient, and will play as low IF ported.
But the Dayons X Max is 8.5 mm compared to 28 mm in the current drivers.
Comments ??
Previous Topic: Tell Us About the Array you built or are building......
Next Topic: Anyone Ever Tried These Drivers In Line Array ?
Current Time: Fri Nov 06 01:59:05 CST 2026
